Question: gridlines do not show on axis when using cmaple.exe
I am now running eveything in cmaple.exe for number of reasons. But I find the plot generated do not show grid lines as it does in worksheet (GUI).
Below is worksheet I used, and below that the .mpl file used for command line with the command used.
plot(x, x=0..1, axis=[gridlines=[10, color=blue]]);
Download why_no_grid_in_cmaple_sept_15_2024.mw
Here is the T.mpl file
currentdir("C:/tmp");  #change as needed
#the following commnad below export a plot to a file
plotsetup(ps, plotoutput="t.ps",plotoptions=`color,noborder`);
p0:=plot(x, x=0..1, axis=[gridlines=[10, color=blue]]):
print(p0); #this will create t.ps in same folder
plotsetup(default); #rest back to default
quit;
Now I run the above as follows
"C:\Program Files\Maple 2024\bin.X86_64_WINDOWS\cmaple.exe"   T.mpl
Next I convert t.ps to t.pdf using Adobt PDF pro. The output is this
You see, there are no grid lines. I tried changing the color to BLUE, but it made no difference. Tried difference colors also. nothing worked.
Is there a way to keep the grid lines when using cmaple.exe?
I also attached  t.pdf converted by adobe from the .ps file. Mapleprime will not let me attached t.ps file.
t.pdf
