Question: is there a limit of how many cmaple.exe can be running at same time?
Currently I run my Maple script in a LOOP which calls cmaple.exe to solve one problem at a time.
So each iteration starts one cmaple.exe and waits for it to finish. Then next iteration repeates this for the next problem. i.e. starts new cmaple.exe process.
So it is sequential process and it can take 5-6 days or more to finish all the problems I have. Running 24 hrs per day.
I am thinking if I can run more than one cmaple.exe at same time, I could change this to have each script process say 10 problems at a time in one cmaple.exe, and have 100 such scripts running at same time. This will speed things a lot.
But this means I need to be able to run 100 cmaple.exe at same time.
I googled to see if there is a limit or any license issues/limitations in running that many cmaple.exe's at same time on same PC, but could not find anything.
Is there a limit in Maple itself to how many cmaple.exe can be running on same PC at same time?
There is no shared files or resources between these scripts, so each solving of a problem is independent. Only shared resource is Maple itself.
Maple 2024.1
