Question: Error, (in content/gcd) too many levels of recursion calling odetest.
I do not remember seeing this before or reporting. Just in case, here is how to reproduce it. This happens also in Maple 2024.2
The problem with these errors is that they can not be cought using try/catch.
I was testing a solution which most likely wrong, but I get
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1866 and is the same as the version installed in this computer, created 2025, May 6, 10:52 hours Pacific Time.`
SupportTools:-Version();
`The Customer Support Updates version in the MapleCloud is 17 and is the same as the version installed in this computer, created May 5, 2025, 12:37 hours Eastern Time.`
sol:=ln((1/9*u(x)*6^(1/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4),3)+1)^(1/3)/(1/81*u(x)^2*6^(2/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4),3)^2-1/9*u(x)*6^(1/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4),3)+1)^(1/6))+1/3*3^(1/2)*arctan(1/3*(2/9*u(x)*6^(1/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4),3)-1)*3^(1/2)) = Int(3/2*(-32*x^(15/2)-6480*A^2*x^(9/2)-65610*A^4*x^(3/2)+720*A*x^6+29160*A^3*x^3+59049*A^5)/surd(-A*(-2*x^(3/2)+9*A)/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4),3)/(-128*x^11-54432*A^2*x^8-1837080*A^4*x^5+4782969*A^7*x^(1/2)-7440174*A^6*x^2+4960116*A^5*x^(7/2)+408240*A^3*x^(13/2)+4032*A*x^(19/2))*A*6^(1/3),x)+2*_C1;
ode:=diff(u(x),x) = -1/18/x^(1/2)*(-576*A*x^(9/2)-11664*A^3*x^(3/2)+32*x^6+3888*A^2*x^3+13122*A^4)/(-2*x^(3/2)+9*A)^3*u(x)^3-1/18/x^(1/2)*(1944*A*x^(5/2)-216*x^4-4374*A^2*x)/(-2*x^(3/2)+9*A)^3*u(x)-1/18/x^(1/2)*(486*A*x^(3/2)-2187*A^2)/(-2*x^(3/2)+9*A)^3;
ln(((1/9)*u(x)*6^(1/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4), 3)+1)^(1/3)/((1/81)*u(x)^2*6^(2/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4), 3)^2-(1/9)*u(x)*6^(1/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4), 3)+1)^(1/6))+(1/3)*3^(1/2)*arctan((1/3)*((2/9)*u(x)*6^(1/3)/surd((-9*A^2+2*A*x^(3/2))/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4), 3)-1)*3^(1/2)) = Int((3/2)*(-32*x^(15/2)-6480*A^2*x^(9/2)-65610*A^4*x^(3/2)+720*A*x^6+29160*A^3*x^3+59049*A^5)*A*6^(1/3)/(surd(-A*(-2*x^(3/2)+9*A)/(-288*A*x^(9/2)-5832*A^3*x^(3/2)+16*x^6+1944*A^2*x^3+6561*A^4), 3)*(-128*x^11-54432*A^2*x^8-1837080*A^4*x^5+4782969*A^7*x^(1/2)-7440174*A^6*x^2+4960116*A^5*x^(7/2)+408240*A^3*x^(13/2)+4032*A*x^(19/2))), x)+2*_C1
diff(u(x), x) = -(1/18)*(-576*A*x^(9/2)-11664*A^3*x^(3/2)+32*x^6+3888*A^2*x^3+13122*A^4)*u(x)^3/(x^(1/2)*(-2*x^(3/2)+9*A)^3)-(1/18)*(1944*A*x^(5/2)-216*x^4-4374*A^2*x)*u(x)/(x^(1/2)*(-2*x^(3/2)+9*A)^3)-(1/18)*(486*A*x^(3/2)-2187*A^2)/(x^(1/2)*(-2*x^(3/2)+9*A)^3)
try
    odetest(sol,ode);
catch:
    print("cought error ok");
end try;
Download content_gce_odetest_error_may_7_2025.mw
