Question: help evaluating an integrand - integrating in u still returns u
I have a huge expression involving psi and phi called A_1 which I paste below.  I am trying to integrate it using the residue theorem in the variable phi. I make a substitution in u as below for sin(k*phi)  and ask for the singularities of each operand at u. But when I get my final result it still has the variable u in it. If its evaluated the integral in u then it should not return u in the result. Evidently it’s done something wrong but I just can’t see what it is. Would you please help me? I’d be grateful for any help. My objective is to integrate A_1 in phi (Maple couldn’t  do it directly so I use residue theorem).  So what I do is for each operand in A_1 I remove terms in psi, I substitute u as below for sin(k*phi), I find the singularity at u, get the residues at those singularities and sum them then multiply by 2*Pi*I. I apologise for the huge output.
This is my expression to evaluate:
(1/(2*Pi)+sin(k*phi))^3*(-320*Pi^2*(((((1/20)*Pi^3-1/1280*I+(1/160)*Pi+(3/80*I)*Pi^4+(1/10*I)*Pi^6)*sin(k*phi)^3-(1/20*(-(3/4)*Pi^4+(1/8*I)*Pi+I*Pi^3-2*Pi^6+1/64))*cos(k*phi)*sin(k*phi)^2+(1/10*(1+cos(k*phi)^2))*((1/16)*Pi-1/128*I+(3/8*I)*Pi^4+I*Pi^6+(1/2)*Pi^3)*sin(k*phi)-(1/20*(-(3/4)*Pi^4+(1/8*I)*Pi+I*Pi^3-2*Pi^6+1/64))*cos(k*phi)*(cos(k*phi)+1)*(cos(k*phi)-1))*exp(-(1/2)*sigma^2*k^2)-(1/5*((1/16)*Pi-1/128*I+(3/8*I)*Pi^4+I*Pi^6+(1/2)*Pi^3))*(cos(k*phi)^2+sin(k*phi)^2)*sin(k*phi))*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)+(Pi^6+(9/40)*Pi^4+(11/160)*Pi^2-(1/160)*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)*Pi^2+1/320)*(1/4+Pi^2)*((-sin(k*phi)^3+I*cos(k*phi)*sin(k*phi)^2+(-cos(k*phi)^2-1)*sin(k*phi)-I*cos(k*phi)+I*cos(k*phi)^3)*exp(-(1/2)*sigma^2*k^2)+2*sin(k*phi)^3+2*cos(k*phi)^2*sin(k*phi)))*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)-(160*(Pi^6+(1/40)*Pi^4+(1/160)*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)*Pi^2-(1/160)*Pi^2-1/320))*(1/4+Pi^2)*Pi*((-sin(k*phi)^3+I*cos(k*phi)*sin(k*phi)^2+(-cos(k*phi)^2-1)*sin(k*phi)-I*cos(k*phi)+I*cos(k*phi)^3)*exp(-(1/2)*sigma^2*k^2)+2*sin(k*phi)^3+2*cos(k*phi)^2*sin(k*phi))*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)+2*Pi^4*((-sin(k*phi)^3+I*cos(k*phi)*sin(k*phi)^2+(-cos(k*phi)^2-1)*sin(k*phi)-I*cos(k*phi)+I*cos(k*phi)^3)*exp(-(1/2)*sigma^2*k^2)+2*sin(k*phi)^3+2*cos(k*phi)^2*sin(k*phi))*((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+((-1/8+(1024*I)*Pi^11-1024*Pi^10+(384*I)*Pi^9-128*Pi^8+(-(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)-80)*Pi^6+(-8*I+(1/2)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2))*Pi^5+(-(1/4)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)-18)*Pi^4+(1/8)*Pi^3*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)-2*Pi^2)*sin(k*phi)^3+cos(k*phi)*(1/8*I+1024*Pi^11+(1024*I)*Pi^10+384*Pi^9+(128*I)*Pi^8+(I*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)+80*I)*Pi^6+(-(1/2*I)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)-8)*Pi^5+((1/4*I)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)+18*I)*Pi^4-(1/8*I)*Pi^3*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)+(2*I)*Pi^2)*sin(k*phi)^2+(1024*(-1/8192+I*Pi^11-Pi^10+(3/8*I)*Pi^9-(1/8)*Pi^8+(-(1/1024)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)-5/64)*Pi^6+(-1/128*I+(1/2048)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2))*Pi^5+(-(1/4096)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)-9/512)*Pi^4+(1/8192)*Pi^3*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)-(1/512)*Pi^2))*(1+cos(k*phi)^2)*sin(k*phi)+cos(k*phi)*(1/8*I+1024*Pi^11+(1024*I)*Pi^10+384*Pi^9+(128*I)*Pi^8+(I*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)+80*I)*Pi^6+(-(1/2*I)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)-8)*Pi^5+((1/4*I)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)+18*I)*Pi^4-(1/8*I)*Pi^3*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)+(2*I)*Pi^2)*(cos(k*phi)+1)*(cos(k*phi)-1))*exp(-(1/2)*sigma^2*k^2)-(2048*(-1/8192+I*Pi^11-Pi^10+(3/8*I)*Pi^9-(1/8)*Pi^8+(-(1/1024)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)-5/64)*Pi^6+(-1/128*I+(1/2048)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2))*Pi^5+(-(1/4096)*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)^(3/2)-9/512)*Pi^4+(1/8192)*Pi^3*(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2)^(3/2)-(1/512)*Pi^2))*(cos(k*phi)^2+sin(k*phi)^2)*sin(k*phi))*t*(1/(2*Pi)+sin(k*psi))/((((1/8)*Pi^4+(1/64)*Pi^2)*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)+Pi^6+(1/64)*Pi^2+(1/4)*Pi^4+1/256+(1/64)*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)*Pi^2-(1/128)*Pi*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2))*((-(1/8)*Pi^4-(1/64)*Pi^2)*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)+8*Pi^2+64*Pi^4+2)+Pi^6+(1/64)*Pi^2+(1/4)*Pi^4+1/256+(1/64)*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)*Pi^2+(1/128)*Pi*sqrt(2*sqrt((-4*Pi^2-32*Pi^4-1)^2+256*Pi^6)-8*Pi^2-64*Pi^4-2))*(cos(k*phi)^2+sin(k*phi)^2)*(1+(1/(2*Pi)+sin(k*phi))^2)^2);
Then this is my code to do it. The final result of integrating each term in phi will end up in a list called h. The output will be large.
> h:=[];# set up a list h to store the results of integrating the terms in phi
for z in op(A_1) do
 s1a := expand(z): s1 := simplify(remove(has, z, psi),size);
s2:=subs(cos(k*phi)=((1-u^2) / (1+u^2)),cos(m*phi)=((1-u^2) / (1+u^2)), sin(k*phi)=((2*u) / (1+u^2)), sin(m*phi)=((2*u) / (1+u^2)),  s1)*1/(1 + u^2);
with(MultiSeries); _EnvExplicit := true; poles1 := singular(s2, u); t1a := map(`@`(rhs, op), [poles1]); p1 := proc (beta,Q,P) options operator, arrow: select(proc (x) options operator, arrow; 0 < Im(evalf(eval(x, [beta = beta, Q = Q, P = P]))) end proc, t1a) end proc; t1 := p1(beta,Q,P); poles2 := []; for i to nops(t1) do u = t1[i]; poles2 := [op(poles2), %] end do; poles := poles2; residues1 := zip(proc (x, y) options operator, arrow; simplify(x*(lhs-rhs)(y)) end proc, `~`[convert](`~`[MultiSeries:-series](s2, poles, 1), polynom), poles);
residue_total1 := 0;
for i to nops(residues1) do residue_total1 := simplify(residue_total1 + residues1[i], size) end do;
result1 := simplify(((2*Pi*I)*residue_total1),size);
h:=[op(h),result1];
> end do;
 p1 above selects the poles with positve imaginary parts.
