Question: Dsolve with two systems of ODEs
I used dsolve to obtain the solution of the attached two systems of ODEs, where the second system depends on the solution of the first one. The obtained results for the first system is accurate, where the obtaind solution of the second one is not accurate. I think the problem is using cubic spline approximation. I would appreciate any advice on how to  obtain accurate results for the second system
