Question: Fsolve inside an integral
I am trying to solve a problem using fsolve. Where the fsolve is inside the integral. I keep getting the following message. Here is what I am trying to do
int(fsolve(int(k*r*PDF(R,r),r=-infinity..x)=0,x)*PDF(Q,z),z=-1..1);
where Q is a normal distribution and R is also normally distributed with its parameter conditional on Q. Following is the error message that I get.
"Error, (in fsolve) z is in the equation, and is not solved for"
I also checked the following post which suggests a solution
http://www.mapleprimes.com/questions/38209-Double-Integration-With-Fsolve-As-A
unfortunately, that did not work for me either. I deeply appreciate any help that is directed towards me. I am attaching a sample .mw file.
Thank you!test.mpl
