Question: Alternative to fsolve and LinearSolve
I want to know which other maple in-built function does the same thing as fsolve and LinearSolve. I can use both to solve systems of equations either by passing the equations directly to fsolve or deciding to generate matrix to be used in LinearSolve while still getting the same result. So, i'm using this medium to ask if there are/is other inbuilt function that does the same/similar thing as the two.
