Question: Strange behavior of the procedure
It is well known that  operating in  geometry  package when setting objects symbolically some inconveniences arise. The error occurs if you do not set limits on the parameters. I wrote the procedure for finding center and radius of the circumscribed circle, devoid of drawbacks:
Circumcircle:=proc(a,b,c)
local x1, y1, x2, y2, x3, y3, n;
uses geometry;
x1,y1:=op(a); x2,y2:=op(b); x3,y3:=op(c);
n:=x2*y3-x3*y2+x3*y1-x1*y3+x1*y2-x2*y1;
point(A,a), point(B,b), point(C,c);
if type(n,realcons) then triangle(T,[A,B,C]); circumcircle(cc,T,'centername'=OO);
return [coordinates(OO),radius(cc)]  else assume(n<>0);
simplify([coordinates(OO),radius(cc)]); fi;
At initial startup procedure works correctly:
Circumcircle([x1,y1], [x2,y2], [x3,y3]);
But if you change the arguments of the procedure, an error occurs:
Circumcircle([x1,1], [x2,y2], [x3,y3]);
But if you run the procedure again with the same arguments, the error disappears:
What is the reason?
Circumcircle.mws
