Question: is there a lack of proper writing of parameters in this case
I have found the value of t1 and T, but I am unsure of the value. t1 and T in this case is the initialization time at the which the inventory level to zero in Reaches
warehouse. whether possible negative value? is there a lack of proper writing of parameters in this case? so that the output of t1 and T is negative? thanks a lot
> TC := (p*A*((lambda-sigma)*(exp(lambda*t2)-1)+lambda*(exp((lambda-sigma)*T)-exp((lambda-sigma)*t2)))/(lambda*(lambda-sigma))-Ca-A*exp(lambda*t1)*((beta*a2+b2)*(exp(beta*t1)-1)/beta^2-(lambda*a2-b2)*(1-exp(-lambda*t1))/lambda^2)/(beta+lambda)+A*exp(lambda*t1)*b2*t1/(lambda*beta)-W*((alpha*a1+b1)*(1-exp(-alpha*t1))-alpha*b1*t1*exp(-alpha*t1))/alpha^2+A*(exp(lambda*t2)*((a1+b1*t2)*lambda*alpha+b1*(lambda-alpha))-exp(lambda*t1)*(b1*(alpha^2-lambda^2*exp((lambda+alpha)*(t2-t1)))-(a1+b1*t1)*lambda*alpha*(alpha+lambda*exp((lambda+alpha)*(t2-t1))))/(lambda+alpha))/(lambda^2*alpha^2)+Cs*A*exp((lambda-sigma)*t2)*((T-t2)*(lambda-sigma)-exp((T-t2)*(lambda-sigma))+1)/(lambda-sigma)^2-L*A*((exp(lambda*T)-exp(lambda*t2))/lambda-(exp((lambda-sigma)*T)-exp((lambda-sigma)*t2))/(lambda-sigma))-C*(A*(exp((beta+lambda)*t1)-1)/(beta+lambda)+W+A*(exp((lambda-sigma)*T)-exp((lambda-sigma)*t2))/(lambda-sigma)))/T;
> TC2 := subs(t2 = (ln(W*(lambda+alpha)/A)+(lambda+alpha)*t1)/(lambda+alpha), TC);
> x1 := diff(TC2, t1) = 0;
> x2 := diff(TC2, T) = 0;
> x3 := evalf(simplify(lhs(eval(subs(A = 200, lambda = 0.3, a2 = 2.4, b2 = 0.01, a1 = 0.9, b1 = 0.01, alpha = 0.01, beta = 0.04, W = 100, Ca = 90, L = 7, C = 10, p = 15, Cs = 3, sigma = 0.25, x1)))));
> x4 := evalf(simplify(lhs(eval(subs(A = 200, lambda = 0.3, a2 = 2.4, b2 = 0.01, a1 = 0.9, b1 = 0.01, alpha = 0.01, beta = 0.04, W = 100, Ca = 90, L = 7, C = 10, p = 15, Cs = 3, sigma = 0.25, x2)))));
> x5 := fsolve({x3, x4}, {T, t1});
          x5 := {T = -15.72808468, t1 = -12.55374671}
