Question: how to solve differential equations with variables interdependent
i am using maple to solve a system of ordinary differential equations , 3 unknows (x,y, x ), and 3 equations (dx/dt,dy/dt,dz/dt)
there is one known variable denpendent on x and z
# code begins here
if x(t) <= z(t) then Q(t) := 8 end if;
if x(t) > z(t) then Q(t) := 10 end if;
eq1 := diff(x(t), t) = 3*x(t)-1;
eq2 := diff(y(t), t) = y(t)+Q(t);
eq3 := diff(z(t), t) = z(t);
eqs := {eq1, eq2, eq3};
# code ends here
above i put the system of ODEs, the code maybe illegal in maple, but i wrote in this way to make it clear.
Q is dependent on x and z.
in the past, when i was trying to solve ODEs, normally, eqs contains with only x,y,z as unknowns. but in this eqs, clearly, Q is included as an unknown.
i've tried to use piecewise function to express Q(t), but failed.
how could i solve a system like this? thanks
