Question: Maple Toolbox for Matlab: Segmentation Violation?
Hi MaplePrime-ers,
I'm using Maple17 in Matlab 2012b to evaluate a symbolic function over a grid of values.  The number of values is generally ~500k, and therefore I have a loop that dumps the solutions into MATLAB where the values are parsed and stored more efficiently.
I put this proceess in an optimization routine, and I keep getting crashes.  The crashes are NOT repeatable.  They generally happen after 4-10 times the routine has been called.
This is one of the stack dumps.  Anybody have any ideas?  I talked to MATLAB support, but they weren't very useful (they started pointing fingers).
Segmentation violation detected at Wed Jun 4 17:38:11 2014
Configuration:
Crash Decoding : Disabled
Current Visual : 0x24 (class 4, depth 24)
Default Encoding: UTF-8
GNU C Library : 2.15 stable
MATLAB Root : /opt/Matlab/R2012b
MATLAB Version : 8.0.0.783 (R2012b)
Operating System: Linux 3.2.0-37-generic #58-Ubuntu SMP Thu Jan 24 15:28:10 UTC 2013 x86_64
Processor ID : x86 Family 6 Model 23 Stepping 6, GenuineIntel
Virtual Machine : Java 1.6.0_17-b04 with Sun Microsystems Inc. Java HotSpot(TM) 64-Bit Server VM mixed mode
Window System : The XFree86 Project, Inc (40300000), display wildnode0:15.0
Fault Count: 1
Abnormal termination:
Register State (from fault):
RAX = 00007f3bcc0a80c0 RBX = 00007f3b97fe6000
RCX = 0000000000000000 RDX = 00007f3bcc0a84a0
RSP = 00007f3b8cb29d60 RBP = 0000000000000003
RSI = 5851f42d4c957f2d RDI = 00007f3bde026360
R8 = 65a1566174cc9e28 R9 = 0000000000000002
R10 = 00007f3b8cb29d90 R11 = 0000000000002e88
R12 = 0000000000000001 R13 = 00007f3b8cb29df0
R14 = 0000000000000000 R15 = 0000000000000003
RIP = 00007f3b977d0604 EFL = 0000000000010283
CS = 0033 FS = 0000 GS = 0000
Stack Trace (from fault):
[ 0] 0x00007f3c962b01de /opt/Matlab/R2012b/bin/glnxa64/libmwfl.so+00516574 _ZN2fl4diag15stacktrace_base7captureERKNS0_14thread_contextEm+000158
[ 1] 0x00007f3c962b14b2 /opt/Matlab/R2012b/bin/glnxa64/libmwfl.so+00521394
[ 2] 0x00007f3c962b2ffe /opt/Matlab/R2012b/bin/glnxa64/libmwfl.so+00528382 _ZN2fl4diag13terminate_logEPKcRKNS0_14thread_contextE+000174
[ 3] 0x00007f3c9559f093 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00557203 _ZN2fl4diag13terminate_logEPKcPK8ucontext+000067
[ 4] 0x00007f3c9559bb9d /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00543645
[ 5] 0x00007f3c9559d835 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00550965
[ 6] 0x00007f3c9559da55 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00551509
[ 7] 0x00007f3c9559e0fe /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00553214
[ 8] 0x00007f3c9559e295 /opt/Matlab/R2012b/bin/glnxa64/libmwmcr.so+00553621
[ 9] 0x00007f3c93a86cb0 /lib/x86_64-linux-gnu/libpthread.so.0+00064688
[ 10] 0x00007f3b977d0604 /opt/maple17/bin.X86_64_LINUX/libmaple.so+01824260
[ 11] 0x00007f3b977cfc48 /opt/maple17/bin.X86_64_LINUX/libmaple.so+01821768
[ 12] 0x00007f3b977d2f88 /opt/maple17/bin.X86_64_LINUX/libmaple.so+01834888
[ 13] 0x00007f3b9763d63f /opt/maple17/bin.X86_64_LINUX/libmaple.so+00173631
[ 14] 0x00007f3c93a7ee9a /lib/x86_64-linux-gnu/libpthread.so.0+00032410
[ 15] 0x00007f3c937ab3fd /lib/x86_64-linux-gnu/libc.so.6+01000445 clone+000109
If this problem is reproducible, please submit a Service Request via:
http://www.mathworks.com/support/contact_us/
A technical support engineer might contact you with further information.
Thank you for your help.
