Question: How to create a "rating" question?
How do you create a "rating" question type in Maple T.A.? I.e. a question of the following kind:
"rate this and that" and ask the students to select an answer from the list {1, 2, 3, 4, 5}. To this kind of question there is no correct answer. The grade should be the chosen number.
Edit: I just found that this kind of question is called a "Likert-scale question".
