Question: How do I solve two PDEs together while they are not simple?
Dear users,
In my attached file I have two PDES, (PDE1 and PDE2). PDE1 is a function of v(t) and w(x,t) and PDE2 is also a function of v(t) and w(x,t). I can solve PDE2 if I say v(t) is 1 for example and you can see the plot. But what if I put v(t) back in PDE2 and want to find v(t) and w(x,t) from PDE1 and PDE2 together?
Many Thanks,
Baharm31
Define PDE Euler-Bernoulli Beam
Parametrs of piezoelectric and cantilever beam
Ys := 70*10^9: # Young's Modulus structure
Yp := 11.1*10^10: # Young's Modulus pieazo
ha := -0.00125: # Position
hb := 0.001: # Position
hc := 0.0015: # Position
d31 := -180*10^(-12): # Piezoelectric constant
b := 0.01: #Width of the beam
tb := 0.002:
epsilon33 := 15.92*10^(-9):
hp :=0.00025: # Position
hpc := 0.00125: # Position
YI := b*(Ys*(hb^3- ha^3)+Yp*(hc^3-hb^3))/3: # Bending stiffness of the composit cross section
cs := 0.564: # The equivqlent coefficient of strain rate damping
ca := 0: # Viscous air damping coefficient
Ibeam := (b * tb^3 )/12: # The equivalent moment of inertia
m := 0.101: # Mass of the structure
upsilon := - Yp*d31*b*(hc^2-hb^2)/(2*hp): # Coupling term
lb := 0.57:# Length of the structure (Cantilever Beam)
lp := 0.05:# Length of the Piezoelectric
R:= 10000: # Shunted resistor
Electrical circuit equation
PDE1:=(epsilon33 * b*lp / hp) * diff(v(t), t) + (v(t)/R)+ int(d31*Yp*hpc*b* diff(w(x, t),$(x, 2))*diff(w(x, t), t),x = 0..lp)=0;
0.3184000000e-7*(diff(v(t), t))+(1/10000)*v(t)+int(-0.2497500000e-3*(diff(diff(w(x, t), x), x))*(diff(w(x, t), t)), x = 0 .. 0.5e-1) = 0
(1.1.1.1)
PDE Equation
fn := 3.8:# Direct Excitation frequency;
wb(x,t) := 0.01*sin(fn*2*Pi*t):#Direct Excitation;
plot(wb(x,t),t = 0 .. 0.25*Pi,labels = [t,wb], labeldirections = ["horizontal", "vertical"], labelfont = ["HELVETICA", 15], linestyle = [longdash], axesfont = ["HELVETICA", "ROMAN", 10], legendstyle = [font = ["HELVETICA", 10], location = right],color = black);
FunctionAdvisor(definition, Dirac(n,x));
[Dirac(n, x) = (1/2)*(Int((I*_k1)^n*exp(I*_k1*x), _k1 = -infinity .. infinity))/Pi, `with no restrictions on `(n, x)]
(1.2.1)
PDE2 := YI*diff(w(x, t),$(x, 4))+ cs*Ibeam*diff(w(x, t),$(x, 4))*diff(w(x, t), t)+ ca* diff(w(x, t), t) + m * diff(w(x, t),$(t, 2))+ upsilon*v(t)*(Dirac(1,x) -Dirac(1,x-lp) ) =-m*diff(wb(x, t),$(t, 2))-ca*diff(wb(x, t), t);#PDE
1.567812500*(diff(diff(diff(diff(w(x, t), x), x), x), x))+0.3760000000e-11*(diff(diff(diff(diff(w(x, t), x), x), x), x))*(diff(w(x, t), t))+.101*(diff(diff(w(x, t), t), t))+0.4995000000e-3*Dirac(1, x)-0.4995000000e-3*Dirac(1, x-0.5e-1) = 0.583376e-1*sin(7.6*Pi*t)*Pi^2
(1.2.2)
tmax := 0.3:
xmin := 0:
xmax := lb:
N := 20:#NUMBER OF NODE POINT
bc1 := dw(xmin, t) = 0:
bc2 := dw(xmax, t) = 0:
bc3 := w(xmin, t) = 0:
ic1 := wl(x, 0) = 0:
Maple's pdsolve command
bcs := { w(x,0)=0 , D[2](w)(x,0)=0 , w(0, t) = rhs(bc1), D[1](w)(0, t)= rhs(bc1), D[1,1](w)(lb,t) = rhs(bc2), D[1,1,1](w)(lb,t) = rhs(bc2)}; # Boundary conditions for PDE2.
{w(0, t) = 0, w(x, 0) = 0, (D[1](w))(0, t) = 0, (D[2](w))(x, 0) = 0, (D[1, 1](w))(.57, t) = 0, (D[1, 1, 1](w))(.57, t) = 0}
(2.1)
PDES := pdsolve(PDE2, bcs, numeric, time = t, range = 0 .. xmax, indepvars = [x, t], spacestep = (1/1000)*xmax, timestep = (1/1000)*tmax);
module () local INFO; export plot, plot3d, animate, value, settings; option `Copyright (c) 2001 by Waterloo Maple Inc. All rights reserved.`; end module
(2.2)
PDES:-plot3d(t = 0 .. tmax, x = 0 .. xmax, axes = boxed, orientation = [-120, 40], shading = zhue, transparency = 0.3);
Download Euler-Bernoulli_Beam-last_version.mw
