Question: DocumentTools Retrieve function returns the message "unable to retrieve label reference"
Hi
I'm trying to use the command: DocumentTools[Retrieve](path,label), but i recieve the message "unable to retrieve label reference" no mather what i do. When i use the GUI: Insert - reference and get the value it works fine, but in that way I can't assign the value to a variable in the document.
here is an example:
The document i want to retrieve a value from:
a := 5;
#a gets the label (1)
The document i want to retrieve the value to:
with(DocumentTools);
path := FileTools:-JoinPath(["test.mw"], base = worksheetdir); = "C:\Users\Nicolai\CloudStation\Nicolai\Skole stof\Sem 7\test.mw"
Retrieve(path, "());
Retrieve(path, "(1)");
Retrieve(path, "a");
#None of the above works
Is it even possible to do such thing?
with best regards
Nicolai
