Question: Printed Graph in Table is compressed and clipped
When I print a Table with graphs in it, the graphs are compressed vertically to an extreme extent. There has to be some compression from the screen, of course, since I have a wide-screen (although the actual worksheet does not use the whole screen width because of the palette and the fact that I don't use full-screen mode. However, the vertical compression  (that is, in a direction where there is plenty of room on the page) is many times more than the horizontal compression. In order to get the printed graph to look normal, I have to stretch the screen graph vertically an extreme amount, which, of course, looks horribly distorted on the screen.
Also when printing a graph as part of a Table, the graph area is clipped so that the title and legend do not print.
I thought that the Table struction would be a good way to display related graphs. But this behavior is making the use of Tables tedious and much less satisfactory because of the missing titles and legends.
None of these things happen when I print a graph in a regular execution group outside a Table structure.
Has anybody else had this problem, and have you found a way to avoid the compression and get the legends?
