Question: Error trying to Solve unknown variable within a determinant.
Hi there,
I am trying to compute the following, and I am getting this error.
> A := map(convert, M, unit_free)*Unit('m'*(1/'s'^2));
(I had to put the Unit('m'*(1/'s'^2)) because the original units were kNm/s^2 (kg), and even though I simplified it, it's still using kNm/s^2, and leaves the m/s^2 for some reason when I try to remove the units. I tried simply changing the units on the original matrix, but the units menu has disappeared from the right-click menu!!)
> B := map(convert, K, unit_free);
Loading RealDomain;
solve;
Error, (in assuming) when calling 'Engine:-Dispatch'. Received: 'should not happen: Rename expects the input to contain unknown functions'
Why is it giving me this error? omega is an unknown variable that I am trying to solve for. I am going a modal analysis, so maybe there is a better way to find omega?
Any help appreciated!
Raquel
