Question: Is maplev for Emacs still supported?
I ran into a problem mentioned here before: With lots of code in one execution group, the standard GUI editor becomes very slow at least in older versions of Maple (I have reason to believe that this is mostly fixed in Maple 17 and, presumably, newer). With one of my packages this has become enough of a problem to force me to deal with it (and Modules and Packages have to be all in one execution group). I have some machines that cannot go beyond Maple 15 so I keep my stuff compatible with it (so far not a big sacrifice).
The fix is rather easy: In the GUI, export the code as "Maple Input" which creates a file with extension .mpl. Then, in the GUI have a small file that uses "read" to read-in and execute the code (of the module). In my case, I have the necessary LibTools statement to save as a .mla right after the package code ends so, bingo, I have just updated the package. I edit the .mpl file in Emacs.
So I installed Joe Riel's Emacs mode maplev-mode.el. This works rather well. However, it took not long for it to show its age: it does not recognize the multi-line comments (*...*). This is kind-of bad as this forces me to not use quotes in the comments since they mess-up the keyword highlighting esp. when using single quotes as in "I'll" and so on. Likewise, maplev-indent-buffer messes up the whole buffer as it interprets the multiline comments as code.
So my question is: is someone still working on this and using it?? I guess I can work around some of these things, but it would be nice if this worked.
Incidentally, my version of maplev-mode.el seems to be dated June 2005.
I know Joe is here on occasion, maybe he can chime in. It is not absolutely fatal; I could forgo using maplev, but if I am forced to go this route of readin in the package; using maplev-mode at least gives me something in return. Unfortunately my elisp skills are not quite up to fixing this myself; at least not in a reasonable time.
If it is relevant: I use Emacs 22.1 on Mac OS X. Yes, I could upgrade to at least Emace 23.4, if that were the issue.
Thanks in advance,
Mac Dude
