Question: Graphs in the Question Designer
I am trying to design a question, where studenst have to find the equation of a linear function given its graph. For this to work, I have to be able to draw gridlines, which for some reason is not possible in Maple TA with the ordinary plot function. I know it should be possible using an applet; given the problems this is going to create with all the different browsers, however, this is not a viable solution. I have found another solution which is unreasonably complex but should work. The problem is that sometimes it doesn't work. When I press Refresh algorithm preview in the Question Designer I get "Broken Maple plot. Verify your plot statement" roughly every third time I refresh the preview. Any help would be greatly appreciated.
The algorithm is here:
$a1=range(-4,4,1);
$a2=range(1,4,1);
condition:not(eq($a1,$a2));
$px=range(0,5,1);
$y0=range(0,5,1);
$x0=if(gt($a1,0),$px,-$px);
$f=$a1/$a2*(x-$x0)+$y0;
$G=plotmaple("
 plots[display](
  [plots[coordplot](cartesian, [-10 .. 10, -10 .. 10], grid = [11, 11], color = grey),
   plot($f, x = -10 .. 10, y = -10 .. 10, color = [green, blue, red], thickness = 2, tickmarks = [[1], [1]], labels = [``, ``]),
   plots[textplot]([0, 10, 'y'], align = {above, right}),
   plots[textplot]([10, 0, 'x'], align = {above, right})
  labels = [``, ``], axes = normal, view = [-10 .. 10, -10 .. 10]),
 plotoptions='width=350,height=350'");
$g=gcd($a1,$a2);
$at=$a1/$g;
$an=$a2/$g;
$a=if(eq($an,1),$at,$at/$an);
$ans=$a*x+($y0-$a*$x0);
