Question: Generating a series
Hello maple prime users
I have used the sequence command and series command in Maple before, but seem to have hit a little hurdle with a particular problem.
I want to run the expression:
h(a,b,c):=b!*(a+c)!*sum(F,n=0..c)
   Where F:=(-1)^n*binomial(c,n)*N(a+n):
   Where N(a):=(-1)^n*[evalf(ln(2)) - 1 + 0.5 -1/3 + 1/4 +... + (-1)^a/a]:
I ran a test case using the following code:
a:=1:
b:=2:
c:=3:
tot:=0:
F:=((-1)^(a+n)/(a+n)):
for n from 0 to c do
      Seq_F2:=(-1)^(a+n):
      Seq:=[seq(F,n=0..n)];
      Seq2:=convert(Seq, `+`);
      final:=Seq_F2*(evalf(ln(2))+Seq2);
      SS:=(-1)^n*binomial(c,n)*final;
      S:=(b!*(a+c)!)*SS;
      tot:=tot+S;
od:
tot;
This works for the case where a =1, but will not work for a>1 as in the N(a+n) sequence it misses out the terms in the series for a-1, a-2 etc.... So when a = 2 it misses out the -1 of the sequence and when a = 3 it misses out the -1 and 1/2. Are there any tips on how to overcome this?
Best regards
- Yeti
