Question: Ways to make the file you are writing compact and easy to handle with
Hello people in mapleprimes,
I have a question:
What are you doing when you use maple in calculating, for example, your paper,
to avoid missing, for example, variables you use, or for your needs to look back the outcomes you obtained before?
If this is a paper-using work, on considering what to do next, you will read some pieces of papers you wrote and
on which you had calculated and obtained necessary equations. But, with small monitor 13 inch, and with
inconvenience of dealing with things in PC, compared with papers, I feel some stress in using maple in writing a paper.
So, now, I am asking you what kind of methods you has devised to make what you are writing compact and easy,
for you to handle with what you are writing.
I know surely that there are the document block, which enables output or input to not be shown, the workbook,
which is helpful in putting attached worksheets or jpg files together at one workbook, and the distinction of ":" and ";",
which in the case of the former, hides expressions in the outcome.
But, yet, I want to ask you about the ways you use to make it easy to write something.
If you have some, I will be very glad if you show it here.
Best wishes.
taro
