Question: Conversion of this mathematica expression to Maple syntax
I am not unfamiliar with the Wolfram syntax but also not very good with it, and there is a particular element in a Mathematica code I have been given which I do not entirely understand how to efficiently write in Maple. The basic idea is to read in a list of expressions from an external file (LIST) and process the non zero elements and assign them to a function (COEF) which can be called later on. Here is the Mathematica exert:
k = 0;
i = 0;
a = b = \[Theta];
Do[k = k + 1; KK = LIST[[k]];
  If[KK =!= 0, i = i + 1; ff = Factor[KK];
   COEF[x,y, z, l_, m_, n_] = ff], {z, -2,
   2}, {y, -2, 2}, {x, -2, 2}];
The LIST has the following form and only contains l, m and n and another factor E which is left undefined for now. It does not contain x, y or z. The LIST can contain any number of terms depending on the problem. Here is an example:
LIST={0, 0, 0, 0, 0, 0, 0, a^2 b m (-1 + n) n (a^2 + b^2 - 2 E), ... ,0,0, a^3 n(l+1+m) ... }
So the Do loop cycles through the LIST and extracts out the non zero terms. What I am unsure about is how it is looping over x,y and z when they do not appear in the LIST at all. I assume it is attaching a x,y,z combination to each COEF and they can be called like this:
COEF[0,1,1,0,2,3]
For the instance of when x=0, y=1, z=1, l=0, m=2 n=3. Is this correct? What would be the best way to replicate this in Maple?
- Yeti
