Question: Simplifying very large matrix elements
I have a Maple code which generates a matrix, saves it to a .txt file and this is then read in to a C++ program. I have hit a snag with these matrices, in that they are generating absolutely enourmous .txt files. I need to get to a 5000*5000 matrix yet a 200*200 is generating a 100MB file.
The matrix elements contain a lot of algebraic terms which I would like to keep general as these are defined in the C++ code. They also contain hypergeometric functions which in the example below I have left unsimplified (although they are simplified before reaching C++). I have tried various operations/combinations to simplify, but the file sizes still come out very large.
From previous experience expanding the expressions and then simplifying allows Maple to "do more" with it, but it does not seem to work in this instance. I have tried map(options,expr), simplify(expr,options), combine(expr,options), convert (expr,options) etc... The script attached only contains a small example 10*10 matrix on its own without the code which generates it due to the size of the code. What is the best way to simplify these matrices to generate the smallest .txt file?
Large_Matrix.mw
Any help is appreciated.
-Yeti
