Question: Can I set limit on number of cores Maple uses ?
As I understand it, Maple will detect and use the available cores in a system, if the calculation is suitable for multi-core use.
As I am installing Maple on a multi-user cluster, using a scheduler to run maple scripts, I want to ensure the maple jobs only use the number of cores allocated to the job.
Is it possible to set the number of cores used ?
If I have misunderstood how Maple works (I am new to it), or if there is a section in the documentation which explains this, please point me in the right direction.  I haven't found this info so far.
