Question: How to solve Laplace transformations of systems of differential equations
My question is: Use the laplace transform to solve the system.
dx/dt + d^2y/dt^2 = 5e^(2t)
dx/dt - x - dy/dt + y = 8e^(2t)
x(0) = 2, y(0) = 1, y'(0) = 1
What I've done in Maple:
with(inttrans);
with(DEtools);
eq5 := (diff(x(t), t)+diff(y(t), t$2) = 5*exp(2*t), t, s);
eq5s := laplace(%, t, s);
eq6 := (diff(x(t), t)-x-(diff(y(t), t))+y = 8*exp(2*t), t, s);
eq6s := laplace(%, t, s);
solve({eq5s, eq6s}, {laplace(x(t), t, s), laplace(y(t), t, s)});
subs({x(0) = 2, y(0) = 1, (D(y))(0) = 1}, %);
eq3 := invlaplace(%, s, t);
How do I simplify?  If you plug it into maple I come up with an answer that has x and y on each side.  I guess I'm just wondering how I can set them equal to each other to solve and get rid of the variable x and y.  I know answer is correct as I've also ran it through ODEtest.  Please help.
However you figure out getting rid of the variables I assume will help me also in solving the next problem:
Use the Laplace Transform to solve the system
dx/dt = 7x - y + 6z
dy/dt = -10x + 4y - 12z
dz/dt = -2x + y - z
x(0) = 5, y(0) = 7, z(0) = 2
I have attempted the second problem much like the first.  Thank you for your time.
