Question: How to properly determine roots when the solution contain a set of parameters ?
Hello everyone,
First I want to thank you for paying attention to my post.
I'm trying to determine the maximum of the following function:
Maple Code:
(1/4)*(-1/4+alpha*(-1+b)*e^2+((1-b)*alpha+(1/4)*b)*e)^2/((-1+e)^2*(b*e-1)*alpha*e*(-1+b))(1/4)*(-1/4+alpha*(-1+b)*e^2+((1-b)*alpha+(1/4)*b)*e)^2/((-1+e)^2*(b*e-1)*alpha*e*(-1+b))
e is my variable and I want to study it in [0,1[. I have a several parameters restriction like b in [0,1[ and alpha>1.
When I value this function for specific values (b=0.1, alpha=4 for instance) I get the equation and its associated graphic representation:
Maple Code:
-0.6944444445e-1*(-1/4-3.6*e^2+3.625000000*e)^2/((-1+e)^2*(.1*e-1)*e)
I'm only interested in the domain where e is betweeen 0 and 1. I clearly on the graph see that there is a maximum and when 1) I compute roots of the expression I get 2) following solutions:
1)
2)
    0.9324708634, 0.07447358108, 0.6965691592, 1.345632810,
      -0.07419084270.
Here: 0.6965691592 corresponds to the maximum I'm looking for.
So now when I try to get a generalization of this function according to my parameters and when I compute the first derivative with respect to e
I find only 3 solutions and I cannot understand why
1)
2)
3)...
the last is very big so I do not write it here.
To sum-up: I see that the solution I'm looking for exists but when it comes to use parameters I cannot define correct roots.
