Question: Difference between with(geometry) and with(plots? rectangle - color?
I am perplexed about the geometry and plots packages.  When starting a programme involving geometric shapes, how does one decide which to use?  ..Or can the two packages be used in the same programme?  To iiiustrate my question there is a text program below which draws a diagram of a large square, with a circle inscribed tangentially to the square.  There is then a further smaller concentric circle, with a square drawn inside; the vertices touching this circle.  (It isdesigned as a problem suitable for young high-school teenagers.)
   I wanted to fill in various regions of this diagram in colors red and green.  I believe the with(geometry) package does this easily.  However, as I'm more used to the with(plots) package I stuck to this.  To get the coloured regions I drew a sequence of colored lines.  I also drew a colored square (See    SmallSq:=[op(SmallSq),sq_small||ii]:   ) by drawing a seq of concentric squares.  At the end of my program there are two almost identical plots[display] commands.   The difference is that the first does not incude the SmallSq.  I was expecting the two displays to be identical, since I'd specified the color white.  The first display has a dark colored square.  Why?? .
   .   The program is very klutsy!  I'm embarrassed to publish it:-(  The SmallSq is adequate for my purposes, but has several white spaces - almost dots - on the dark version.  The thickness and style of the lines was the widest possible  - perhaps I should have set the larger rarius R, to a bigger value?
   And I have a feeling this diagram could have been constructed ib the geometry package in far fewer lines of code!
As always, any comments, suggestions would be most appreciated.
  David
> restart:
# Maple 7
> # Area puzzle involving squares & circles
> #To Do:  fill areas with color
> #  Use segment command and seq to make a set of colored lines
> #NB  Numbering for lines L1 is 1,2,3,4 for N,E,S,West
> #    Numbering for lines L2 is 1,2,4,3 for N,E,S,West
> with(plots):
> with(plottools):
> print(`The diagram shows two squares and two circles.`);
> print(`The red and green regions are equal in area.`);
> print(`To find the ratio of the radius of the large circle to the
> smaller.`);
> #Doesn't seem to like a combination of geometry & with plots
> #with(geometry);
> r:=R*sqrt((4-Pi)/(Pi-2));  #for the pretty printout only!
> R:=49:
> r:=R*sqrt((4-Pi)/(Pi-2)):  #give r a numerical value
> c_big := circle([0,0], R, color=red):
> c_small := circle([0,0], r, color=green):
> sq_big := rectangle([-R,R], [R,-R], color=white):
> #sq_small := rectangle([-r/sqrt(2),r/sqrt(2)], [r/sqrt(2),-r/sqrt(2)],
> color=white):
> #y:=R/2:
> SmallSq:=[]:
> for ii from 1 to round(r) do
> sq_small||ii := rectangle([-ii/sqrt(2),ii/sqrt(2)],
> [ii/sqrt(2),-ii/sqrt(2)], color=white,linestyle=1 , thickness=3):
> end do:
> Llines1:=[]:Llines2:=[]:Llines3:=[]:Llines4:=[]:
> for yy from 1 by 1 to R do
> l1||yy := line([-R,yy], [-sqrt(R^2-yy^2),yy], color=red, linestyle=1 ,
> thickness=3):
> l2||yy := line([sqrt(R^2-yy^2),yy], [R,yy], color=red, linestyle=1 ,
> thickness=3):
> l3||yy := line([sqrt(R^2-yy^2),-yy], [R,-yy], color=red, linestyle=1 ,
> thickness=3):
> l4||yy := line([-sqrt(R^2-yy^2),-yy], [-R,-yy], color=red, linestyle=1
> , thickness=3):
> #List of lines is Llines
> Llines1:=[op(Llines1),l1||yy]:
> Llines2:=[op(Llines2),l2||yy]:
> Llines3:=[op(Llines3),l3||yy]:
> Llines4:=[op(Llines4),l4||yy]:
> end do:
> first:=round(r*(sqrt(2))/2)+1:
> last:=round(r):
> L2lines1:=[]:L2lines2:=[]:L2lines2D:=[]:L2lines3:=[]:L2lines3Up:=[]:L2
> lines4:=[]:
> for yy from first by 1 to last do
> l2_1||yy := line([-sqrt(r^2-yy^2),yy], [sqrt(r^2-yy^2),yy],
> color=green, linestyle=1 , thickness=3):
> #l2_2||yy := line([yy,r/sqrt(2)],[yy,sqrt(r^2-yy^2)],  color=green,
> l2_2||yy := line([yy,sqrt(r^2-yy^2)],[yy,0],  color=green, linestyle=1
> , thickness=3):
> l2_2D||yy := line([yy,-sqrt(r^2-yy^2)],[yy,0],  color=green,
> l2_3||yy := line([-yy,-sqrt(r^2-yy^2)],[-yy,0],  color=green,
> l2_3Up||yy := line([-yy,sqrt(r^2-yy^2)],[-yy,0],  color=green,
> l2_4||yy := line([-sqrt(r^2-yy^2),-yy], [sqrt(r^2-yy^2),-yy],
> L2lines1:=[op(L2lines1),l2_1||yy]:
> L2lines2:=[op(L2lines2),l2_2||yy]:
> L2lines2D:=[op(L2lines2D),l2_2D||yy]:
> L2lines3:=[op(L2lines3),l2_3||yy]:
> L2lines3Up:=[op(L2lines3Up),l2_3Up||yy]:
> L2lines4:=[op(L2lines4),l2_4||yy]:
> end do:
> plots[display](c_big,c_small,Llines1,Llines2,Llines3,L2lines1,L2lines2
> ,L2lines2D,Llines4, L2lines3,L2lines3Up,L2lines4,
> scaling=constrained);
> plots[display](c_big,c_small,Llines1,Llines2,Llines3,Llines4,L2lines1,
> L2lines2,L2lines2D,L2lines3,L2lines3Up,
> L2lines4,SmallSq,scaling=constrained);
Warning, the name changecoords has been redefined
Warning, the name arrow has been redefined
  To find the ratio of the radius of the large circle to the small\
        er.
                                     4 - Pi
                         r := R sqrt(------)
                                     Pi - 2
