Question: How to solve numericaly a multi-point problem for ODE?
Maple easily solves multi-points problems for an ODE, if the equation can be integrated analytically.
For example, the following 3-points problem  is solvable:
dsolve([diff(y(x), x$3)+diff(y(x), x$2)+y(x)=1, y(0)=0, y(1)=0, y(2)=1], [y(x)]);
But a similar problem cannot be solved numerically.
For example,
dsolve([diff(y(x), x$3)+diff(y(x), x$2)+y(x)=1, y(0)=0, y(1)=0, y(2)=1], [y(x)], type = numeric, 'output' = Array([seq(k/5, k=0..5)]));
generates: Error, (in dsolve/numeric/process_input) boundary conditions specified at too many points: {0, 1, 2}, can only solve two-point boundary value problems
I need to solve a certain number of multi-points problems for ODE systems numerically. Maybe, for this there are some workaround?
