Question: batch file and directory
Hello people in mapleprimes,
I have two files: a batchfile named test.command, and a mpl file,
both in <<my home directory>>.
And, the codes written there are, for the test.command,
/Library/Frameworks/Maple.framework/Versions/2017/bin/maple test.mpl > output.txt
And, for the mpl file,
1+1;
diff(x^2,x);
int(x^3,x);
The test.command was made executable with chmod u+x  test.command, in advance.
From my home directory, I can run the test.command, and obtain output.txt with the result of the calculation of
the mpl file. The above things have no problem.
My question is a following.
When I moved the two files, the batch file and the mpl file, to /Users/myname/Desktop/maple_test,
I cannot get maple to exhaust the appropriate output.txt but an error message, saying it could not read the mpl file.
What should be done to the contents of two files?
I hope you will teach me about this.
Thanks in advance.
taro
