Question: Maple worksheet wont show output
I was making a maple worksheet (out of functions from another), when i noticed that  execution groups and new execution groups that i was making were not showing an output.  I'm wondering why this happens, and how it can be fixed.
in more detail there are 4  [> groups of commands, the first two give the correct output when i hit enter, however, if enter is pressed on any group of commands after the second the command wont return the any output.
I believe this is a formatting issue that comes from the way i cut/paste and edited the previous worksheet down to this, but i'd like to understand so i can avoid it happening again.
3d_plot_of_Lie_derivatives_against_Dimensions_of_solutions_timer.mw
Ahh, this is a teathing problem, I had been using writeto so i could store measurements of RAM; this changes the nature of the question.
How do you implement writeto so only some things are sent there? (in the case of this worksheet the output of GTS2usage
