Question: How do I run coding with goto on Maple?
Hi, I'm using Maple 2018 and I tried to run coding from https://www.maplesoft.com/applications/view.aspx?sid=4194&view=html
however, it said : unable to parse. I figured out that the problem maybe is in the if loop. though it seems perfectly fine, but it has some goto commands that i cannot search on maple website. does this mean that the goto cannot be used here and should be replaced? if yes, then how?
i am still learning on how to use maple. any help would be much appreciated. thank you!
this is the coding for if loop:
label_7;
> rv:=vector([p1(x1pt,x2pt),p2(x1pt,x2pt)]):
> numgeval:=numgeval+1;
> printf("%5d (%8.4f,%8.4f)",numIter,rv[1],rv[2]);
> max:=n;
> mg:=convert(sqrt(dotprod(rv,rv)),float);
> printf("%12.4f",mg);
> if(mg<tol or numIter>=max) then
> goto(label_6);
> else
> numIter:=numIter+1;
> fi;
> v1:=x1pt+t*rv[1];
> v2:=x2pt+t*rv[2];
> newt:=evalf(subs({x1=v1,x2=v2},f1));
> numfeval:=numfeval+1;
> lam:=fsolve(diff(newt,t)=0,t,maxsols=1);
> nv1:=evalf(subs({t=lam},v1));
> nv2:=evalf(subs({t=lam},v2));
> printf(" (%8.4f,%8.4f)%13.4f\n",x1pt,x2pt,lam);
> x1pt:=nv1;
> x2pt:=nv2;
> goto(label_7);
> label_6;
> printf("\n\n-----------------------------------------");
> printf("---------------------------------------------");
> printf("\n\n Approximate Solution: ");
> printf(" (%8.4f,%8.4f)\n",x1pt,x2pt);
> Fvalue:=evalf(subs(x1=x1pt,x2=x2pt,f));
> printf(" Maximum Functional Value: ");
> printf("%21.4f",Fvalue);
> printf("\n Number gradient evaluations:");
> printf("%22d",numgeval);
> printf("\n Number function evaluations:");
> printf("%22d",numfeval);
> end:
