Question: How to convert to float for trignometrical functions
Hi All,
I have been using trignometric functions where the inputs are sometimes intergers. When ever I am having an interger as argument for trignometric functions the out is unevaluated.
expression := 3*sin(z)+9*sin(x)*(1/4);
values := [x = 1, z = 1.570796327];
Now if I evaluate the above expression
eval(expression, values);
output is something like below
3.+9*sin(1)*(1/4)
but if I change the x value from 1 to 1.0
expression := 3*sin(z)+9*sin(x)*(1/4); values := [x = 1.0, z = 1.570796327];
My output is 4.893309716;
I am doing ths inside a procedure hence I cannot change the values to float manually, Is it possible to change the intergers to floats when using trig functions??
Thank you
