Question: How to save a Maple file on a text mode only server?
I'm using Maple on a compute server (via Putty from my computer which has windows system). It is an only-text mode server so it is a black screen and text and no menu bar to choose file and then save by clicking etc. You only can write commands and press Enter.
The IT section suggested to use writeto("filename.txt"), but I can't see any file on my drive, I used writeto("\drvename\filename.txt"), but still nothing.
Thanks to @acer@Joe Riel and the IT section. The problem now is solved. It was about the way that I was writing the directory path. I had to add something before the "drivename" in my case. Plus that it is a Unix path, so I should use / not \.
