Question: How to tell Maple to give the highest order of derivative of a variable in an expression?
Assume we have an expression in several variables, x,y,z,..., where all of them are function of one parameter, t, for an example consider the following simple expression;
f := 2*y(t)*(diff(x(t), t))^2+3*(diff(x(t), t$3))-3*x(t)*(diff(y(t), t));
Is there any command or a way to ask Maple to give the highest order of derivation of x or y with respect to t in the expression? For example in the above example, the answer for x is 3 and for y is 1. If we remove the second term, then the answer for x should be 1.
