Question: Cannot evaluate multivariable integral
integral.mw
I am trying to evaluate any which way the integral:
int(exp(-(sqrt(4*x^2+4*y^2+4*z^2)^3)), z = -sqrt(4-x^2-y^2).. sqrt(4-x^2-y^2),y=-sqrt(4-x^2)..sqrt(4-x^2),x=-2..2);
The program just hangs, so i click on 'stop current operation'.
Then I tried:
evalf(Int(exp(-(sqrt(4*x^2+4*y^2+4*z^2)^3)), z = -sqrt(4-x^2-y^2).. sqrt(4-x^2-y^2),y=-sqrt(4-x^2)..sqrt(4-x^2),x=-2..2));
It returns the integral back unevaluated.
It's true that I could use a change of variables, changing to spherical coordinates would be best here. But I would like to know if I did set up the original Cartesian integral correctly. Is there some workaround I can apply to get a numeric answer. I am satisfied with a decimal approximation. Then I can compare to the change of variable result. An exact answer would be even better of course.
