Question: Trouble converting units directly from evaluation
I've recently changed to maple 2019, from the 2016 version as my license for that product had expired.
However I find it really frustrating that often upon evaluating an expression I can't convert the units.
For instance I had a calculation that evaluated to:
2.114163508*10^7 [kg/s^2]
When I try to directly replace the units within maple to instead be [J/m^2] I recieve the following error message:
"Error, (in  Units:-TestDimensions) 'op(3, i) does not  evaluate to module"
There is no explanation for this error when I try to look it up. However if I once again manually write the answer:
2.114163508*10^7 [kg/s^2] and use the replace units function.
No problem.
I find this quite annoying and frustrating and I hope you can help.
Best regards
Anders Alexander Wagenblast
