Question: How to preserve the order when extracting the coefficients?
Hello (again)
I thought I won't need help with that type of question but I came across an example that says otherwise.  Here it is
vars:=[x,y,z];
model7 := [x*(-RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)-5/4)+y*alpha[1, 2]-33/(32*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)), x*z*alpha[2, 6]+y*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561), x^2*(17*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)+17)/(alpha[1, 2]*alpha[2, 6])-17*x*y/alpha[2, 6]+2*z*x-z-(163/32+RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)^2+5*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)*(1/4))/(alpha[1, 2]*alpha[2, 6])]
then I issued the command
map(w->coeffs(w,vars),model7);
to get
[-33/(32*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)), -RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)-5/4, alpha[1, 2], RootOf(64*_Z^3+80*_Z^2+1104*_Z+561), alpha[2, 6], -(163/32+RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)^2+5*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)*(1/4))/(alpha[1, 2]*alpha[2, 6]), -1, (17*RootOf(64*_Z^3+80*_Z^2+1104*_Z+561)+17)/(alpha[1, 2]*alpha[2, 6]), -17/alpha[2, 6], 2]
clearly the order does not follow model7's.
I have also tried
[seq(coeffs(expand(model7[i]), indets(model7[i], suffixed({vars[]}))),i=1..nops(model7))];
Is there a solution to it?
Many thanks (again)
Ed
