Question: On making LinearAlgebra[LinearSolve] return just one result, not all
Hi there:
I have a short question. For an algorithm, I need a solution to a linear equation, and I use LinearAlgebra[LinearSolve]. In the case of
0            0                    0
5            0                    0
for example, there are infinitely many, however, so Maple returns (_t2,0). My algorithm just needs one solution, if there are multiple ones, then any (except for _t2=0) is fine. However, if (_t2,0) is the saved solution, the algorithm later breaks down, since it does not expect the extra variable. Is there any way to tell Maple to replace every variable with, say, 1 when solving such an equation?
