Question: Error, (in discont/zero) too many levels of recursion. Unable to catch
This was generated when running some code on Maple 2020.1.
Just wondering if this might indicate some problem internally, or is this something that can happen.
ZZ:=Int(-(a*_a^2+(_a^4*a^2-4*_a*b*y(x))^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*b*y(x))^(1/2)+6*y(x)),_a = _b .. x)+Intat(-2/(a*x^3+x*(a^2*x^4-4*_f*b*x)^(1/2)+6*_f)-Int(2/(_a^4*a^2-4*_a*_f*b)^(1/2)*b*_a/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)+(a*_a^2+(_a^4*a^2-4*_a*_f*b)^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)^2*(-2*_a^2/(_a^4*a^2-4*_a*_f*b)^(1/2)*b+6),_a = _b .. x),_f = y(x))+_C1 = 0;
timelimit(30,value(ZZ))
The problem is that I am not able to trap the error. This does not work
try
timelimit(30,value(ZZ));
catch:
  print("ignore");
end try;
Why can't one catch this error inside try/catch? It means the whole program can not  continue.
Maple 2020.1
Update Jan 9, 2025
This bug is still in Maple 2024.2. Will check again in 5 years. May be someone in Maplesoft will fix it by then.
Int(-(a*_a^2+(_a^4*a^2-4*_a*b*y(x))^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*b*y(x))^(1/2)+6*y(x)), _a = _b .. x)+Intat(-2/(a*x^3+x*(a^2*x^4-4*_f*b*x)^(1/2)+6*_f)-(Int(2*b*_a/((_a^4*a^2-4*_a*_f*b)^(1/2)*(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f))+(a*_a^2+(_a^4*a^2-4*_a*_f*b)^(1/2))*(-2*_a^2*b/(_a^4*a^2-4*_a*_f*b)^(1/2)+6)/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)^2, _a = _b .. x)), _f = y(x))+_C1 = 0
Download not_fixed_jan_9_2025.mw
