Question: Is it possible to use notzero in PolynomialSystem to eliminate only the trivial solution?
Hello
I am not familiar with the use of notsero in SolveTools:-PolynomialSystem. Is there any special syntax to use it?  In the following example, the trivial solution {x=0,y=0} is to be eliminated.
SolveTools:-PolynomialSystem({x*(x^2 - 2), y*(y^2 - 2)}, {x, y},explicit=true)
If I issue the command
SolveTools:-PolynomialSystem({x*(x^2 - 2), y*(y^2 - 2)}, {x, y},{x,y},explicit=true)
all roots with either x=0 or y=0 are eliminated.
Can netzero be used to eliminate only the trivial solution?
Many thanks
