Question: How to best control a maplesim simulation with external python code
Hi
I have constructed a model of an UR5e in maplesim with the hop to be able to test my controller writen in python on it.
I hope to be able from the model to
  • Enter a tourqvalue for the joints.
  • Extract joint angles, joint velocitys as well as the forces and tourqes that affects the end effector.
  • (If posible) visualize the sumulated robot arm so I can se that the motion reflects that of the real robot arm.
the simulated robot arm
The question is how to best do this in a semi realtime way?
I have been looking into generating a FMU but if there are other ways to do this, then I am open to ides.
The contorller is based on a haptic algoritm for connecting two robot arms and I will only get one robot arm due to prise and space constraints.
This means that I will reseave realtime information from the real robot arm into my python controller that then i supose to take inforamtion from the simulated arm and with information from both arms calculate the tourqe values for both arms joints.
Thanks in advance for all youre help
Eric Ragnarsson
