Question: How to get Grid Run execute in parallel?
I was hoping to run two procs: tgf3 and tgf4 in parallel using Grid, Run and get a faster execution time. As I understood the description of Grid Run, the first call to Grid Run will run in the background and before it is finished the second call Grid Run will start. I do not believe I have that situation in my script. I am not understanding Grid Run. How can this problem be fixed? Here is just a portion of the script using Grid Run:
Use Grid Run 0 for tgf3 and 1 for tgf4. Determine the real time and compare times. The Grid Runs do not appear to run in parallel.
rgt := time[real]();
Grid:-Run(0, `~`[tgf3@op](convert(L, listlist)), 'assignto' = ans3roots);
Grid:-Run(1, `~`[tgf4@op](convert(L, listlist)), 'assignto' = ans4roots);
ans3roots;
ans4roots;
GridRunTime := time[real]() - rgt;
                     GridRunTime := 44.074
Here is my script:
Grid_Run_2.mw
Thank you for your help.
