Question: how to check if expression is polynomial but coefficients are not complex?
I need to check if an expression is polynomial in x but with coefficients that are either symbolic, or do not include the complex numebr I.
The problem is that maple considers integers and reals complex also.
type(1,complex) gives true. so I can't use
type(1+2*x,polynom(Not(complex),x))
Since this gives false.
I could instead list all the types to be accepted using Or, like this
type(1+2*x,polynom(Or(float,realcons,rational,integer),x))
But I might overlook something if I have to enumerate every type accepted. It is easier to just exclude complex numbers.
What is the correct way to tell Maple to check if expression is polynomial in x where coefficients do not have the complex I in them? It it ok if the coefficient are any other numeric value, or a known Maple constant, or a parameter (symbol). I just want to exclude complex numbers.
I know I could do this
the_poly:=1+2*x;
if not has(the_poly,I) then
   type(the_poly,polynom(anything,x))
else
   print("not allowed");
fi;
But I wanted to learn how to make a type which excludes complex numbers.
Maple 2021.1
