Question: how to make forget(expand) work in a procedure?
I was expanding an expressions, and found that Maple expands trig also. Then found there is a way to turn that off. Which is great. I tested it in my worksheet and it works. But when I put the same code inside my module, I get an error.  It seems like some scoping issue which I do not understand.
Here is a MWE
expr:=(1+x)*sin(3*x+k);
forget(expand);
expand(expandoff());
expandoff(cos,sin,exp);
F:=expand(expr);
forget(expand);
which gives
Which does what I want. But inside a proc, the code fails
foo:=proc(expr)
local F;
forget(expand);
F:=expand(expr);
forget(expand);
end proc;
And now when calling it as
expr:=x*sin(3*x+k);
foo(expr)
What Am I doing wrong? And how to make it work? I need to prevent expand() from expanding these functions. Help says that expand has memory table, and I want to clear that before and after doing this, so it does not affect later code.
Maple 2021.1
Update
I just found out, if I add a restart before defining my function, then the error goes away
forget(expand);
F:=expand(expr);
forget(expand);
restart;  # had to add this. But why??
foo:=proc(expr)
local F;
forget(expand);
F:=expand(expr);
forget(expand);
end proc;
foo(expr)
#no error. now it works
I need this to work repeatedly inside a module, so I can't do restart each time ofcourse like the above.
Even if I do restart before defining the function, next time I call it, it will fail:
foo:=proc(expr)
local F;
forget(expand);
F:=expand(expr);
forget(expand);
end proc;
foo(expr); #OK
foo(expr); #FAILED
Very strange.
