Question: why select is not selecting the term I want?
I can't figure this one out.
I need to pick out the subexpression   anything*sin(3*x) from an expression.
it works, when the expression is   anything*sin(3*x)+something else. But when the expression is exactly  anything*sin(3*x) then select returns 1 and not anything*sin(3*x) as I was expecting.
So I must be doing something silly, but do not see it.
TypeTools:-AddType('type_1', '`*`'({anything,identical(exp(3*x))}));
expr:=25*A[1]*exp(3*x);
type(expr,type_1);
returns true. good. Now I test it on
select(type,expr+sin(x),type_1) ;
and this returns what is expected. 25*A[1]*exp(3*x) but when I type
select(type,expr,type_1) ;
it return 1
reading select help page did not help.  Tried flatten, inplace.
I can do this using patmatch
patmatch(expr,a::anything*exp(3*x),'la');la
But why is select not working in the above? What is the correct way to do this so it works for a*expr+anything and also for a*expr only? This is done inside a function and not interactive. So I need it to work for both cases, since the input can be anything, but I only need the term anything*exp(3*x) pulled out.
