Question: How do I solve the Error, "invalid input: rhs expects 1 argument, but received 2"
Hello.
I wrote some codes for solving equations in a special way. My codes work very fine when my differential system has only one equation.
But when I extend it to a system that has two or more equations, sometimes does not work and I face with error. However, in one system (2 eq) it also works. But it is only a special case. If you want, I can upload it here as well.
I am attaching the maple file containing the error. You can observe it.
By examining many cases, I think that maybe the root of the problem is that I must change my codes in a way that they are for a "system". Indeed, instead of writing codes for each differential equation, I must define a system and write these codes for a system containing some differential equations.
However, I think that the boundary conditions sometimes also may be the root of the error.
I change the attached codes for this purpose, but I failed. I prefer to not present my wrong codes for this purpose.
If it is possible, help me to change my codes.
Thanks a lot.
ERROR.mw
