Question: Any twin command for "timelimit", but about memory?
The timelimit command of Maple can be used to do a computation if it uses less than a given amount of time, otherwise generating an error message that can be cought by try ... catch. Now my question is that there exists any similar command, but with a limitation on memory usage, not the time usage. I don't mean what datalimit in kernelopts can does, because I am not going to limit the memory usage of the whole Maple session, but just a command which may be used inside a larger procedure etc.
