Question: Determine whether a point with known coordinates is within a given polygon with known verticies
Hello
Imagine you have an irregular polygon as follows:
restart; with(plottools):with(plots):
display(polygon([[0,0],[200,0],[200,300],[250,400],[500,300],[500,500],[0,500]]),color=yellow,linestyle=solid,thickness=2);
with vertices that can be easily defined, and that you have an arbitrary point P(x,y) with coordinates of (x) and (y). I want Maple to check whether the point P(x,y) is inside or outside the polygon. In Matlab, the command (inpolygon) can be used for such a task. Is there a similar readily available command in Maple.
Thank you very much for your help and support.
