Question: why remove works different on diff(y(x),x) vs. one symbol?
When doing
item:=x;
res:=remove(has,item,x);
Maple returns, as expected
But when item is not a single symbol, say sin(x) or diff(y(x),x), then it no longer returns ()
item:=diff(y(x),x);
res:=remove(has,item,diff(y(x),x));
It does not return () but it now returns the input itself, as if it was not removed.
Why is that, and how to make it return () also on composite expression?  I tried flatten and inplace option. Otherwise, I will have to do a special test before.
The strange thing is that it works on
item:=2*diff(y(x),x);
Now it returns as expected. So now it did remove diff(y(x),x). But it does not remove it when it is on its own. I assume this is by design. But it is not intuitive to the user. One would expect it to work same way on removing `x` or `sin(x)` or `diff(y(x),x)`
