Question: infolevel gives different output depending on order used
I set infolevel[dsolve]:=2; and first time I use it, it gives very long output. Next time I use it on same ode with same command it gives much shorter output.
Why is that and how to make it give the shorter output from first call?  This is very strange behavior.  One would expect the same output each time. The worksheet attached shows that first time it is used, the output is very long. At the end of the worksheet the call is made again with same infolevel, and now output is much smaller.
(getting error uploading worksheet. Will try again. Unable to do insert content keep getting error from this site. So I am just attaching it as link. May be due to large size of the worksheet)
infolevel_changes.mw
