Question: First timelimit hang discovered in Maple 2022
I knew it can't be true that timelimit in Maple 2022 no longer hangs and it is only a matter of time before I find a case where it still hangs.
Here are examples. timelimit hangs. No error or anything, it just hangs. timelimit is just ignored. set the limit to 60 seconds  (CPU time), and waited for 20 minutes (real time) and nothing happend.
I hope in Maple 2023 this will be fixed. Could others confirm this? it only hangs when adding the method=_RETURNVERBOSE otherwise it does not hang.
`Standard Worksheet Interface, Maple 2022.0, Windows 10, March 8 2022 Build ID 1599809`
Examples of timelimit hangs in Maple 2022
Example 1
integrand:=(B*x+A)/(c*x^2+b*x+a)^2/(f*x^2+e*x+d)
try
  timelimit(60,int(integrand,x,method=_RETURNVERBOSE));
catch:
  print("Timed out");
end try;
Example 2
integrand:=(5*x^4-x^3+3*x^2+x+2)*(2*x^2-x+3)^(1/2)/(5+2*x)^3
try
    timelimit(60,int(integrand,x,method = _RETURNVERBOSE));
catch:
  print("Timed out");
end try;
Download int_hangs.mw
